polishing valve cover?
Old Mar 11, 2005 | 03:21 PM
hypnotixcrx's Avatar
Default polishing valve cover?
anyone know the best way to polish a valve cover, chemicals, sanding what?
Old Mar 11, 2005 | 07:27 PM
sickcivic420's Avatar
Default RE: polishing valve cover?
clean, sand, polish, buff
Old Apr 10, 2005 | 12:15 AM
ineedhp's Avatar
i used a dremel tool to do mine. but be careful not to spend too much time in one area or it will look like ****. or you could sand it down and paint. up to you.
Old Apr 10, 2005 | 11:36 AM
sacicons's Avatar
ive seen good results from paint thinner.
Old Apr 10, 2005 | 11:45 AM
PhilStubbs's Avatar
getting the paint off is usually really easy, you can almost just tell the paint to get off and it will, but polishing it is tough. it is made from very cheap aluminum and will require a lot of sanding and then hope you dont sand more in one area than another or you will get waves in it. my advice would be to chrome it.
Old Apr 12, 2005 | 02:44 AM
altezza's Avatar
i tried polishing mine with a grinder but used the polishing wire wheel instead it worked great but then i started getting waves in it and it was damn near impossible to get it perfect so i said screw it and painted it
DanoATX
Jan 25, 2010 01:08 AM
addiction2bass
Oct 9, 2009 03:25 PM
EG6
Mar 7, 2009 07:32 AM
neon3kgt
Jan 20, 2006 11:44 PM
mill$civic
Oct 31, 2005 06:25 PM
