i think its the timing belt noise...
Old May 15, 2005 | 07:35 PM
bleedhondos's Avatar
Default i think its the timing belt noise...
I'm not to sure if it is coming from my timing belt. The car is about 30k miles on it and recently i got the radiator flush plus a tires rotation. The car is making a loud squeaking nosie while it idle. I took a look at the timing belt and it seem the belt is ok nothing is wrong with it. Any suggestion on what the problem is or where its coming from?
Old May 15, 2005 | 10:30 PM
Super Mario's Avatar
Default RE: i think its the timing belt noise...
Pulley bearing gone bad.
Old May 17, 2005 | 03:30 PM
you think that the case eventho its only 30kmiles on it??
Old May 18, 2005 | 12:10 AM
happened on my mom's 98 caravan after only 45000, so might as well check. what you can do is take a newspaper, roll it up into the shape of a funnel and put the larger end toward tharea that you think is making noise, while you put the other end up to your ear. Then move it around until the noise is the loudest. then you've found the problem! And it was actually the idler pulley that went out on the caravan.
Old May 19, 2005 | 04:31 PM
thanks i'll check it out
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
n8te81
Feb 28, 2008 11:26 AM
nardva
Oct 8, 2005 12:58 PM
