01 civic shifting into 3rd gear will grind unless clutch is held in for awhile or under 3000 rpms
Old Jan 6, 2007 | 11:11 AM
ajfd90's Avatar
Default 01 civic shifting into 3rd gear will grind unless clutch is held in for awhile or under 3000 rpms
It seems like the gear keeps spinning for awhile after the clutch is pushed in, this is the only gear that does this at all. Is it a transmission problem ,or someone told me to check my fluids or adjust the clutch. Any help at all would be great
Thanks
Old Jan 6, 2007 | 01:19 PM
Misha's Avatar
Default RE: 01 civic shifting into 3rd gear will grind unless clutch is held in for awhile or under 3000 rpms
That's a known Honda problem. You need your syncro replaced. Meanwhile you can use heavier oil in your tranny to minimize this. I believe someone reported that using GM syncromesh oil almost solved the problem for him.
Old Jan 7, 2007 | 12:27 AM
ajfd90's Avatar
Definite newbie here, i appreciate the help, but could you expand on what a syncro is.....thanks
Old Jan 7, 2007 | 12:35 AM
Misha's Avatar
In two words - this is the thing that actually truns your gears on and off. You can google it for more info, and find lots of sites with explanation, like this one:
http://www.singster.co.uk/mascot%20m...003%20(4).html
new2honda
Dec 22, 2014 07:52 AM
Juans_MX3
Apr 9, 2010 05:37 AM
Dipsetcivic117
16
Feb 4, 2010 02:12 PM
bp4131017
12
Dec 16, 2006 11:10 PM
civic_66
Oct 29, 2006 06:37 PM
