03 civic ac pressure switch
Old Aug 14, 2007 | 07:35 PM
crispydeath's Avatar
Default 03 civic ac pressure switch
Does anyone know where the AC low pressure switch is located on an 03?
-Thanks
Old Aug 15, 2007 | 03:59 AM
AgentofDarkness's Avatar
Default RE: 03 civic ac pressure switch
Check on the right side(driver's side) of the engine compartment.The switch is going to have a 2 wire connector going to it. I believe it is in front of the PS pump but the picture isn't that clear.
Old Aug 15, 2007 | 06:45 AM
It appears to be on top of the receiver-drier tank mounted somewhere up front on the left fender (driver's side). Follow the line from the bottom of the condenser to it.
Old Aug 18, 2007 | 03:38 PM
Brian's Avatar
Stand in front of your vehicle and look down and to the right of your rad; you'll see a cannister with two steel lines going into it and your pressure switch mounted on top.
lunger
Jul 10, 2011 02:50 PM
phan10m
Jul 7, 2007 04:27 PM
ic892003
Mar 4, 2007 08:37 PM
b16Ek4
Jun 20, 2005 10:59 PM
b16Ek4
May 25, 2005 08:48 AM
