05 EX - Bolt threaded out near oil pan
Old Mar 30, 2012 | 02:13 PM
beastyben1's Avatar
Default 05 EX - Bolt threaded out near oil pan
05 EX with 186,000 miles. Head gasket and machining done 2 months ago. Last timing belt was at 106,000.
Noticed this bolt was pinned up against the a/c pulley. Doesn't look like a Honda bolt and has a large washer on it preventing it from being screwed in.
What's going on here? Any comments on the surrounding oil leak would be helpful as well. HG repair included valve cover gasket.
Old Mar 30, 2012 | 03:01 PM
droopy128's Avatar
Doesn't look original, but seem like a modified timing belt cover bolt.
Old Mar 30, 2012 | 03:07 PM
beastyben1's Avatar
Oh I think I'm following. The lower corner of the TB is missing? Someone used this setup to secure it instead of getting a new TB cover?
Old Mar 30, 2012 | 10:38 PM
droopy128's Avatar
I believe the cover bottom corner piece is broke, so someone use a bigger washer for leverage to hold it in. Can't remove/replace the bolt without removing the crank pulley, and definitely will hear grinding noise when loose.
Old Mar 31, 2012 | 06:41 AM
beastyben1's Avatar
Is a new TB cover required? Or should I just tighten the screw and call it a day?
Old Mar 31, 2012 | 08:29 AM
You could try just tightening it. Be careful not to break that sensor nearby, without it the engine will not run at all.
Old Mar 31, 2012 | 11:28 AM
beastyben1's Avatar
Great I'll give it a shot. Thank you everyone for your replies, much appreciated.
saiguanas
Jul 6, 2008 05:53 AM
oilltd
Jun 10, 2008 04:06 PM
kokasian
15
May 10, 2007 07:53 PM
red2000Si
Nov 28, 2006 12:45 AM
