1991 Civic DX bad auto tranny
Old Jul 16, 2011 | 10:41 PM
betulie11's Avatar
Default 1991 Civic DX bad auto tranny
what is the process to swap to a 5 speed? Will one out of a 89 CRX work?
Old Jul 16, 2011 | 11:57 PM
zerojett's Avatar
yes, that will work.
you will need the pedal assembly, transmission, transmission mounts, axles I believe, shift linkage, shifter assembly, engine harness, ecu, flywheel, clutch, flywheel cover, clutch cable
probably easiest to drop the motor, unbolt the transmission, unbolt the torque converter, unbolt the flywheel, bolt on the manual flywheel, clutch, pressure plate, install shift linkages on car, install ecu, run wires for the reverse lights from the shifter console to the engine bay (they will connect to the reverse switch coming off the transmission), hook up the ECU, swap the engine harness (not sure if you need to do it), swap pedal assembly, install clutch cable, hook everything up and install engine and pray it works.
there's tutorials online, no doubt
kairus
May 8, 2012 01:45 PM
TheOne
Jul 29, 2008 05:28 PM
davster
Sep 28, 2007 10:23 AM
SirTealingstonThe2ND
Jul 5, 2007 09:48 AM
ic892003
Nov 29, 2006 06:53 PM
