2000 Civic ex idle problems??
Just picked up a 2000 civic ex, It keeps throwing the CEL for po505. I searched the forum and thought it was the IAC valve. I cleaned it and replaced the Gasket for throttle body and im still having the same problem when warmed up the idle jumps between 1400-1800 when in park. Any ideas as to what else will cause this problem??? Thanks in advance
P0505 indicates either an IACV problem or a vacuum/intake air leak. If you pull off the air intake and use your finger to cover the port leading to the IACV in the throttle body, does the idle speed return to normal? If not, you definitely have a vacuum or intake air leak. Start by looking carefully for a disconnected vacuum hose. Otherwise the throttle body or IM gasket is leaking. Are they torqued to spec?
honvic
Sep 2, 2011 09:49 PM
KingofSparta
Aug 27, 2010 06:49 PM
jesskendrick
May 15, 2010 10:09 AM
Corn
Oct 13, 2005 03:04 PM
