2000 VP 211K miles rat ride failed CA smog check
Old Mar 24, 2012 | 10:29 AM
low&slow's Avatar
Default 2000 VP 211K miles rat ride failed CA smog check
Hey everyone,
Just wanted to get some expert opinions on my options to spend as little $$$ as possible on my trusty ****ebox
Just failed the CA smog check & here are the fault codes from the test.
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold
P1456
This has been a problem before the last check 2 year ago but then it passed. In the past the CEL would come on & go off on it's own but for the last year has been on full time. MPG is around 30 even though I wring it's neck everyday.
I have the test results with a lot of data I can post if needed.
TIA
Steve
Old Mar 24, 2012 | 10:31 AM
ChristianL's Avatar
Sounds like a new oxygen sensor is in your future. That'll probably clear up the first two codes.
Old Mar 24, 2012 | 11:26 AM
Unplug the primary O2 sensor (closest to the engine) and measure the resistance between the two wires on it that are the same color, which is the heater circuit. I think 10 to 40 ohms is the spec for good. Finding an open circuit, sensor is definitely bad.
Old Mar 26, 2012 | 07:15 PM
low&slow's Avatar
Thanks...I will try that.
Old Mar 31, 2012 | 08:03 AM
low&slow's Avatar
That was it. Open circuit on old sensor & with new sensor no CEL & seems to run a bit better.
brdude
12
Apr 6, 2008 03:46 PM
Partizan
16
Mar 30, 2008 06:19 PM
m0rgansciv
Jan 18, 2008 05:39 AM
Hailchristian
Dec 1, 2007 08:00 PM
viswa01civic
Jul 9, 2007 01:21 PM
