2001 Civic Hazard problem
Old Apr 3, 2018 | 04:27 PM
sad2001civic's Avatar
Angry 2001 Civic Hazard problem
I have a 2001 Civic that has recently started to flash the blinkers after turning off the car, and draining the battery. I've read online about this, so I started with checking all the fuses (under dash/hood non blown and did the in/out thing several times with the fuses), changed the flasher relay, no change, replaced the hazard switch, no change, and just replaced the turn signal switch, no fix but now when I start the car, no turn signals work, no lights on dash, no clicking relay, I turn off the car and the the hazards start to flash, I turn on the headlights and the hazards turn off, this will go on like this several times until the hazards stop flashing completely. I also did the test-light check with the positive cable removed from the batter, clipped the test light to the cable terminal and the probe tip to the positive terminal of the battery resulting in a slow dim pulsing light, pulled each fuse in the car without the test light going off, but the 10amp Hazard under the hood seemed to make it little more dim when I pulled it out. I hope somebody has a clue what all this means because I sure don't...
kjsayers
Jun 10, 2010 10:06 AM
new_2_civics
Mar 31, 2010 05:34 PM
evanSpiddal
Mar 24, 2009 08:27 PM
addiction2bass
Nov 21, 2008 01:46 AM
My04Civic
Sep 9, 2008 08:14 AM
