6 DAYS LEFT! Fix It Ticket For Taillights
Old Nov 4, 2007 | 12:26 PM
FlipHKD720's Avatar
Default RE: 8 DAYS LEFT! Fix It Ticket For Taillights
ORIGINAL: Mr Mobsta Man
Two questions, did you check the fuses under the dash? That is where the headlight and taillight fuses are, not in the engine bay fuse box. Other question would be are your taillights still aftermarket or did you put stock ones on when you de-riced your ride?
theyre the stock ones, and come to think of my parking lights have always been a little weird, sometimes theyd be on, other times they wouldnt be, but i always thought it was the ebay projector harnesses [&:]idk, i'll check fuse 32 like right now
and Matt the switch works i think because my headlights come on when i turn it on, and then it works correctly wtih brights and blinkers to
idk thouhg, i'll be back in a bit with an update...
Old Nov 4, 2007 | 06:15 PM
windcalmer's Avatar
ORIGINAL: FlipHKD720
But if the switch has two contacts then the one that controls the tails might be F'ed up. Or the relay that drive them might be gone to relay heaven. LOL
Old Nov 4, 2007 | 06:29 PM
FlipHKD720's Avatar
checked that fuse 32 is not blown aand its all perfect, even replaced it to make sure, none of the bulbs are getting power (for neither the running light,s tails, or license plate lights), and i got pulled over again tonight for it. SHowed the cop the ticket, just told me to drive with my flashers on and that was that....seriously like out of ideas.
Old Nov 4, 2007 | 06:55 PM
If you are still willing and capable, try this:
Use a multimeter to check for proper continuity between connector C601 in left quarter panel (see larger picture in earlier post) and the taillights.
Lack of proper continuity indicates that your problem is the rear wire harness.
Proper continuity indicates that your problem is the wire harness connecting the #32 fuse wire and connector C601.
You should also consider that the C601 connector itself may be faulty.
Old Nov 4, 2007 | 07:18 PM
wes94si's Avatar
check the switch ,if you have power at the fues
Old Nov 4, 2007 | 07:42 PM
Everyday Getaway's Avatar
If it's getting this close to the "due" date, I would seriously just take it to the dealership and have them look at it for you, usually it doesn't cost anything to address the problem.
Old Nov 4, 2007 | 07:46 PM
I agree with wes94si that you should also test whether the fuse receives power when the lights are switched on.
Old Nov 4, 2007 | 08:11 PM
Pete's Avatar
Check the ground wires on the tailights? If it isnt grounded it wont work. Check to see if the wire coming out of the fuse for the lights is getting juice.....ifit is, then youre just going to have to run a new wire, or follow the original wire and see where it is cut, or disconnected. I would also try......Checking the clips where the lights plug into the wire, make sure the fins are okay, make sure everything is touching......it could be just a loose ground or something simple.......just start by checking the wire behind the fuse for power, then go from there.
ghostbusters101
Dec 15, 2010 07:32 PM
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
WhiteRabbit1021
19
Sep 1, 2009 07:05 AM
SIstyle
Mar 27, 2009 10:00 AM
Hailchristian
Sep 22, 2008 10:55 PM
