89 civic si wont turn over
Old Jan 20, 2008 | 03:11 PM
redalerton20s's Avatar
Default 89 civic si wont turn over
i bought this car ran great for a month then one morning wouldnt start. when i put the key in it sounds like it wants to turn on but just wont turn over what could this be? any help would help thanks tom
Old Jan 20, 2008 | 03:15 PM
Default RE: 89 civic si wont turn over
Winter temperatures are battery killers. If the engine cranks very slowly, then the battery is probably on the way out. Start by charging or replacing it. Clean the battery electrodes and connectors before reinstalling.
Old Jan 20, 2008 | 03:20 PM
no engine cranks over normal has no slugish crank just wont turn on? maybe a strarter or distributer?
Old Jan 20, 2008 | 03:30 PM
I understand. The starter is fine as the engine is turning over. The next step is to determine whether the problem has to do with the fuel or ignition system. Start with the former by turning the ignition key to ON without cranking. You must be in a quiet location. Listen carefully in the rear of the car for the low humming noise of the fuel pump for a few seconds. If you don't hear the humming, then the main relay or fuel pump is bad. If you hear the humming, then next test for spark at the plugs (ignition). Pull one of the plug wires and put a
spark plug in the end of it. Ground the plug on a convenient metallic engine part and crank the engine. You should see a bright spark at the end of the plug if the ignition system is fine. Post the results of the tests in this thread for more feedback.
Old Jan 20, 2008 | 04:23 PM
ok well i need to listen for a huming sound in the rear if no huming it might be the fuel pump is that correct? what part of tx u from
Old Jan 20, 2008 | 04:31 PM
No humming = faulty fuel pump or main relay (powers the fuel pump)
Hoody neighbor -- I'm in the Houston area.
Krunkdamighty
Jul 30, 2011 09:28 AM
Krunkdamighty
Jul 27, 2011 02:13 PM
pascal11110
Jul 17, 2011 05:20 PM
96dx4door
Sep 25, 2007 08:24 PM
99ExCivicCoupe
Jan 26, 2007 08:10 PM
