95 Honda Civic Wont Turn Over
Old Jul 27, 2011 | 02:31 PM
Krunkdamighty's Avatar
Default 95 Honda Civic Wont Turn Over
So my 95 Honda Civic EX more often than not will not turn over. There is an occasional time that it does and once it does it runs fine, but those are few and far between. All it does when I turn the key to start it is lock the doors and stuff like it usually does when you start the car, but the engine doesn't turn over. I initially though it was a bad starter but I just replaced the starter today and it does the same thing. I think it may be a faulty ignition switch, but I can still put the key in the on position and push start it which makes me think that it may not be the ignition switch. Any ideas what the problem might be? Could it still be the ignition switch? A bad connection somewhere? Help please!
Old Jul 27, 2011 | 02:48 PM
droopy128's Avatar
you may have a faulty cable that connect to your starter, check that cable for power when you can't start, see if it has power.
Old Jul 30, 2011 | 09:28 AM
Well it turns out it was the aftermarket alarm that was put in it that was messing with it and preventing the car to start. So after that was torn out it works fine now
Krunkdamighty
Jul 27, 2011 02:13 PM
pascal11110
Jul 17, 2011 05:20 PM
redalerton20s
Jan 20, 2008 04:31 PM
96dx4door
Sep 25, 2007 08:24 PM
99ExCivicCoupe
Jan 26, 2007 08:10 PM
