'90 civic DX with several issues
Old Nov 20, 2010 | 01:50 PM
seanjrng's Avatar
Default '90 civic DX with several issues
First, Im replacing my transmission (5 speed) and need to know how to check a used one i have in my garage. Second the engine
(d15b2 16valve) lopes at idle and i have no idea why. any advice would be greatly appreciated. Thanks
Old Nov 20, 2010 | 06:40 PM
PunisherInOKC's Avatar
The lope may be related to a vacuum leak.
The engine light doesn't stay on, does it?
And welcome to Honda Civic Forum.
Old Nov 20, 2010 | 07:15 PM
To check the transmission, first spin the input shaft in neutral, it should be absolutely quiet. If you hear noise like a bad bearing that is because the bearings are bad, very common-- but you can open up the transmission and replace them rather simply.
Shift into a gear by twisting and then pushing or pulling the shifter shaft. Then turn the input shaft and note that the differential and output gears (visible through the axle holes) turns. Try this with all 5 forward gears and reverse. You can check the differential (though problems with it are rare) by putting two axles in. Shift into any gear and hold the input shaft still. When you turn one axle, the other one should turn in the opposite direction. If all that seems OK it should be alright to install. Only a test drive will reveal all possible problems though. It'd be good to replace the axle shaft seals while it is out of the car.
Old Nov 21, 2010 | 08:36 AM
seanjrng's Avatar
thanks for the help on the transmission. the engine light does not come on at all. thanks
Old Nov 21, 2010 | 11:53 AM
Do you have any mods on your car, like an aftermarket intake?
If so, does it have the line from the valve cover going to the new intake tube? Mine loped when I didn't have this line connected. Cleared right up when I fixed the issue.
Old Nov 21, 2010 | 01:48 PM
seanjrng's Avatar
i do have an aftermarket intake and the breather line doesent really seal up all that well ill give that a shot thanks. oh and i tried putting on my trans and it wouldnt line up right. i think i have the input lined up right but im being held off somewere. any sudgestions
Old Nov 21, 2010 | 02:34 PM
Check the alignment pins. There is one in the front and one in the back. You may have extra ones (one in each side of the same hole) because they sometimes stick in the engine and sometimes stick in the transmission.
Alignment must be perfect before it will go together. Put the bolts in most of the way and wiggle around until it drops together. Do not try to force together using the bolts.
Old Nov 27, 2010 | 04:20 PM
seanjrng's Avatar
thanks ill give it a shot
Old Dec 25, 2010 | 10:48 AM
seanjrng's Avatar
i got the trans in. thanks guys
Old Dec 25, 2010 | 11:02 AM
seanjrng's Avatar
Oh, btw, there is some kind serious body damage including some frame damage (i bought it on a rebuilt title). If i take it to shop could they do somthing about it or am i stuck with it.
e_rock
Feb 4, 2008 06:25 AM
lubinshan
Jul 23, 2006 10:34 PM
95dx28
Apr 29, 2006 07:18 PM
Deadhead
Feb 25, 2006 02:46 PM
bills99si
Jun 25, 2004 05:48 AM
