'92 Civic DX Cooling Problems
Old May 18, 2011 | 11:34 AM
conceptualpolymer's Avatar
Old May 19, 2011 | 04:23 AM
memacha's Avatar
Hello,
I didn't ask him about thermostat. But I will.
Can high CO emissions cause engine overheat?
Originally Posted by conceptualpolymer
Old May 19, 2011 | 06:02 AM
Actually, high engine heat can result in high NO:
Engine Overheating - Inadequate engine cooling can will high NOx. If your vehicle's cooling system is not working efficiently, (i.e. bad radiator, thermostat, hoses) high NOx will be created. Remember high NOx nitrous oxide is created when an engine's combustion chamber temperatures reach over 2500F. You will want to make sure your vehicle's cooling system is working properly, and your vehicle's temperature gauge is always indicating normal.
Old May 19, 2011 | 06:21 AM
memacha's Avatar
Hello,
when I talked to auto service center guy, I felt that he is not saying any good.
Can I assume that he has no idea why my temperature gauge is going way up to the red mark?
Old May 19, 2011 | 07:25 AM
memacha's Avatar
Hello,
Auto service center guy said that thermostat is in good condition. He is saying it needs new head gasket.
So my question is why is the temperature gauge still going up to the red mark? what is the relation between head gasket and temperature gauge?
I got new radiator, new radiator fan, thermostat is in good condition (from his words); what else I have to check?
Thanks,
Macha
Old May 19, 2011 | 06:02 PM
A bad head gasket can allow super-hot exhaust gasses to boil the coolant and engine oil. A word of advice: If you are driving and notice the gauge sailing toward the 3/4 mark, turn on your heater to full blast and shut your engine as soon as you can. High temperatures can warp an aluminum cylinder head, which would end up costing you much more money than for a head gasket replacement.
Old May 20, 2011 | 08:22 AM
memacha's Avatar
Hello,
I am taking my car to the authorized Honda dealer.
Thanks for all your information
Macha.
Old May 28, 2011 | 10:08 AM
gerryd3's Avatar
If you have a head gasket issue you should be seeing combustion byproducts in your cooling water. If your fan isn't coming on as you near the red zone on your gauge the it's either your switch or the fan motor. Put 12V directly to the fan and see if it runs if not your fan motor could be shot.
doctajoojoo
Feb 21, 2020 12:48 PM
Turtlegrip
Mar 6, 2012 10:50 AM
RicerMcGee
Jun 14, 2011 10:43 PM
dtrscivic
Jul 19, 2010 08:09 AM
civicninja98
16
Oct 1, 2007 02:03 PM
