92 DX - oil in spark plug hole
Old Apr 9, 2007 | 11:05 AM
wehrd1's Avatar
Default 92 DX - oil in spark plug hole
The car is using oil - no evident leaks!! no smoke out exhaust, but its using oil SOMEWHERE. I changed the spark plugs & wires, and noticed thatONE spark plug tube has oil in it.
What would this indicate?? and what does the remedy involve? would this issue also cause poor mpgs?
Thanks for any input.!!
Old Apr 10, 2007 | 09:12 AM
Jhong12226's Avatar
Default RE: 92 DX - oil in spark plug hole
is the oil on top of the thread of the plug? or is it on the tip??
if its on the treads and not on the tip its likely to be your plugs tube seals, they come with the valve cover gasket set if you buy em.
if its on the tip of the spark plug , its leaking inside the cylinder which could be your piston rings.
Old Apr 10, 2007 | 10:24 AM
my94civic's Avatar
have you got oil also in your water...?
Old Apr 10, 2007 | 01:43 PM
riceburner700's Avatar
have you recently had your valve cover off?
Old Apr 10, 2007 | 01:54 PM
INJENalltheway's Avatar
Yeah you might just need a new gasket set. Easy fix.
Old Apr 18, 2007 | 04:41 PM
bgaff's Avatar
same thing happened on my 93 dx..changed seals and its fine now
oilltd
Jun 10, 2008 04:06 PM
daltan
Feb 27, 2007 07:51 PM
FlipHKD720
Feb 5, 2007 09:25 PM
Strike
Sep 16, 2006 09:15 AM
