93 civic noise
Old Nov 22, 2011 | 04:33 PM
thebighammer's Avatar
Default 93 civic noise
i just replaced the rear main,flywheel ,clutch ,preasure plate throw out bearing and oil pan. i used 10/30 engine oil put it all back together and now have this weird noise . the noise kind of sounds like a playing card stuck in the forks of a bike it goes away when the clutch is pressed. i am stumped should the be a additive in the oil.
Old Nov 22, 2011 | 04:52 PM
anibis's Avatar
Sounds like an input shaft bearing...was there any noise before you replaced the clutch?
It's possible the ISB was already going out and was just made worse by pulling the trans....it's a common problem with Honda manual transmissions.
Old Nov 22, 2011 | 05:38 PM
yea lots of noise the dampner spring came apart. i did notice that there was no input shaft seal the snout the bearing slides on was part of the houseing.so in a nut shell it needs rebuilt.
Old Nov 22, 2011 | 07:28 PM
anibis's Avatar
You could just take it apart and replace the ISB, it's not very difficult and would only cost about $30 for the bearing. I would recommend replacing the needle bearing too which is another $20 or so. There's a couple good DIY ISB with pics and step by step directions.
There could be more damage but you won't know until you get in the trans. If it has a lot of miles and you plan on driving it for awhile longer you could go for a full rebuild.
Or you could get a salvaged unit.
marcin69k
May 25, 2007 04:25 PM
malmsteen
Nov 8, 2005 12:20 PM
kerr_iss
Dec 27, 2004 09:48 AM
civicpsycho
Oct 10, 2004 06:18 PM
Squeek
May 22, 2004 12:32 AM
