93 swap question
Old Mar 28, 2011 | 04:23 PM
jordan101's Avatar
Default 93 swap question
i have a 93 cx has almost 400k on motor still runs but losing alot of hp These only came equipped with a 70hp motor. Anyways i have a d15b7 laying around i want to rebuild it and put it in my car. Will everything from my engine now dist., intake ,alternator ext. bolt right on. Also the b7 had an auto tranny will my 5 speed tranny bolt on. Also will my wire harness and ecu work with the b7? The b7 also came out of a 93 civic.
Old Mar 28, 2011 | 05:28 PM
Vartok's Avatar
All D series motors will fit any "D series" Tranny, so it should be plug and play as far as that goes.
Old Mar 28, 2011 | 07:00 PM
jordan101's Avatar
I figured that. My main concern is the ecu and wire harness. Now since the b7 have a 4 wires 02 cant i just use my b8 manifold that way i can just use my b8 harness. And will my p05 ecu work with the b7 or do i need the p06
Old Mar 28, 2011 | 07:25 PM
xbezubzx's Avatar
your car will still run with that ecu.. there might be minor differences in performance if you were to get the correct ecu but if you just want it to run just throw it in..
I think you can just swap the block / head assembly and keep everything else from the car and it will run, but you'd need to change the intake and ECU, convert the exhaust to under car cat and 4-wire sensor, to realize full performance potential.
You would just take the flex plate off then put your flywheel and clutch on to make a former auto motor fit to a manual.
Old Mar 29, 2011 | 08:03 AM
jordan101's Avatar
ok cool thxs
taintedsaint
EG Swaps
May 16, 2008 04:46 AM
EKswapInfo
EK Swaps
Sep 26, 2006 05:33 PM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
