94 Civic DX wont start when hot outside...
Old Jul 7, 2010 | 10:40 AM
  #41
at_home_mechanic's Avatar
my car hesitates and stalls sometimes when i come to a stop sign or red light and only during the summer time could this be the culprit too?
Old Jul 7, 2010 | 10:44 AM
  #42
When was the last basic tune up done (plugs, wires, cap, and rotor)? Any CEL codes?
Old Jul 8, 2010 | 05:13 AM
  #43
no codes and i did a tune up less than 6 months ago i did not replace cap though you think thats it? and im burning oil what could it be besides piston rings?
Old Jul 8, 2010 | 06:35 AM
  #44
Does the CEL work?
Remove the cap and inspect the contact points for damage and corrosion.
Burning oil could also come from a blown head gasket or bad valve stem seals.
Old Jul 8, 2010 | 07:16 AM
  #45
You're saying it drives OK-- normal power, etc. but stalls out when you stop the car?
Old Jul 9, 2010 | 03:15 AM
  #46
yes it will stumble most of the time when i come to a stop and every once in a while it will stall
Old Jul 9, 2010 | 04:14 AM
  #47
Sounds like the IACV then. That part is used to control idle rpm, if it is clogged the car will not keep running at stop signs.
Old Jul 30, 2010 | 02:31 PM
  #48
can someone post a pic of the iacv location wise?
Old Aug 1, 2010 | 03:35 PM
  #49
Old Aug 4, 2010 | 02:13 PM
  #50
ok so i cleaned the iacv and then igot a engine light on and now i have a misfire on all cylinders
