95 Civic EX check engine light on Code 9
Old Aug 26, 2009 | 04:23 AM
Check that the sensor wires are not shorted to ground or to any other wiring (measure at the ECU plug with the ECU unplugged but the distributor plugged in). I think they run on shielded cable through the harness. Make sure the shield ground wire is intact.
Old Aug 26, 2009 | 07:54 AM
OP -- This is done by measuring resistance (Ohms) to ground from either B11 or B12 in the ECU connector. There should be extremely high resistance.
ptw711
Mar 3, 2013 01:36 PM
gracie
Dec 29, 2010 04:42 AM
Ed Fisher
Jun 22, 2010 01:52 AM
ch1ngg
Apr 18, 2006 08:59 AM
