96 civic dx with 99 civic ex motor...FTP help
Old May 29, 2011 | 12:28 PM
ayden2004's Avatar
Default 96 civic dx with 99 civic ex motor...FTP help
Hey all, I am a noob when it comes to this...I have a 96 civic which I swapped out a 99 d16y8 into it. I used the dx harness and added my vtec wires to it, with a p2p c33 ecu from that came with the engine and tranny I got from a wrecked civic...Everything is running great but keep getting cel light for ptank sensor..I have tried the potentiometer trick with to no avail...what are my other options?
Can I do a obd2 to obd1 conversion with a p28 ecu? without having to wire up vtec again? any help would be great...thanks all...
Old May 29, 2011 | 06:22 PM
I suppose it's possible to get a P28 ECU and an OBD2a to OBD1 conversion harness for the ECU. That'll fix the CEL. (OBD1 doesn't look for the fuel tank pressure sensor.) Im not too familiar with this specific issue though.
Old May 30, 2011 | 03:33 AM
ayden2004's Avatar
O.k...thank you...would I have to rewire my vtec or would it be fine wired into the harness I have now?
any help would be great...thank you....
Old May 30, 2011 | 06:54 AM
I would bet it would be fine. All the conversion harness does is it has female plugs on one end that you plug your ECU connections into, and then it switches the wires around into 3 male plugs that go to your ECU. As long as you wired them properly, it'll work fine.
rjdmboy
Jun 12, 2008 06:36 AM
addiction2bass
Sep 6, 2007 02:19 AM
dalifts
ED-EF Swaps
Apr 16, 2005 01:11 PM
hypnotixcrx
Mar 1, 2005 10:10 AM
nwhite82
Dec 2, 2004 01:49 AM
