'96 Honda Civic DX - Won't start, or crank
Old Jun 10, 2010 | 01:26 PM
ericsm's Avatar
almost similar thing happened some days back with my 96 civic. had to take it to the mechanic after banging my head over it for almost an hour
Old Jul 12, 2010 | 06:21 PM
k20mike's Avatar
ok i got almost the same prob with my 98 .i turn the key and all i her is a click coming from the fuse box under the hood .starter is good and all the wires . just no go when i turn the key.
Old Jul 13, 2010 | 04:12 AM
TRWeiss1's Avatar
If you're just hearing a click while cranking, I'd check to ensure your battery connections are nice and tight, and clean. Then, I'd start checking relays and fuses. Good luck!
Old Jul 13, 2010 | 06:44 AM
When you hear a click from the starter-- the relays and fuses are OK, the problem is either a bad / run down battery, bad connections of the battery or ground cables, or bad starter.
To differentiate, measure voltage at the starter between the big terminal that goes to the battery and the starter frame ground while someone turns the key trying to start. If the starter clicks but doesn't turn, and the voltage stays up around 12 volts, the starter is bad.
Old Jul 13, 2010 | 03:37 PM
k20mike's Avatar
the batt is new and i jumpd the starter when it was off the car and it works. but it seem like ther is no power getting to the silonoid.
Old Jul 14, 2010 | 04:00 AM
Jump the starter on the car to be absolutely sure it and the battery and large cables work. Jump the terminal for the small wire to battery (+). Beware of course the engine is going to turn, so make sure it's not in gear.
When you're not getting power to the small wire when turning the key-- if it's manual the problem is usually the switch on the clutch pedal, more specifically the little rubber pad that presses the switch. Automatics have a switch on the shift lever that interrupts the circuit unless it is in park or neutral.
Old Jul 17, 2010 | 02:26 AM
k20mike's Avatar
Well i got the car to start and i feal a little stupid...i was checking around under the dash and found a little black box . The guy who a got the car from a few a few mounths ago didnt tell me he had a antitheft system put it ...i ripd it out and fixd the wireing back to norm and it started the first turn of the key... Thank for the help and advice all..
Old Mar 6, 2020 | 05:47 PM
Alejandro Mendoza's Avatar
Hello,
I'm new to forums so I'm not sure what the procedure is but i will like to give you guys my problem and how I fixed it. My car is a 96' civic sedan manual transmission DX. So basically what happened was that I received a call from my dad and he told me that my car wouldn't start. He said he got out of the car to do some errands and when he went back in to start it, it wouldnt start. No crank, no start. We ended up checking the the battery terminals for corrosion and also checked it to see what the voltage was. That passed so we were in the clear for that check. He then came to the conclusion that the starter was bad but that didn't make sense to me because I hadn't had any problems with it in the past and the fact that it stopped working so abruptly didn't make any sense. He insisted we change it, so we did. Changing the starter did nothing. One thing to note is that the car would run when given a push start. The culprit to my problem ended up being the clutch pedal stop pad. Basically how it works is that this little pad pushes on your clutch pedal switch and allows your car to crank. Because mine was missing the clutch pedal switch would never be pressed so the car wouldn't crank. Bought a replacement at autozone ($7.99) popped that bad boy in and voila, my baby was alive once again. Hope this helps. I also attached a diagram of where the Clutch Pedal Switch is in my car as well as the Clutch Pedal Stop Pad. Also when I went to autozone they didn't have the Clutch Pedal Stop Pad they only had the Break Pedal Pad. They are exactly the same in diameter so they are interchangeable.
showpump2
Apr 17, 2014 01:04 PM
Rwb003
Aug 11, 2013 06:51 AM
thedmanhere
14
Jul 6, 2011 12:12 PM
Mishman420
Oct 2, 2008 04:20 AM
elusive
Aug 23, 2008 01:09 PM
