97 Civic Not starting
Old Feb 16, 2009 | 04:56 PM
chas-1's Avatar
so, are you saying that you could crank the car (spinning the engine over), but it wouldnt run? Then you replaced the cap and it started right up? If this is yes, could it be coincidence, since if you "just waited" it may have started anyway?
Old Feb 17, 2009 | 11:00 AM
dctaz37's Avatar
I tried starting it and yes it cranked over but didn't start. I replaced the cap at that time and it started right up. Coincidence is always possible but replacing it at the same time as it not starting makes it more likely. My theory is that there wasn't enough spark to ignite the gas.
Old Feb 17, 2009 | 07:35 PM
chas-1's Avatar
Well hope thats your fairly easy fix. I dont think that is my problem because i have a recent tune up. (thats not saying the parts cant be bad) I too will try checking my spark the next time it doesnt start. Also, RONJ, do you really think the coil could be bad? It just seams, past experience, a coil usually has either a strong or weak fire. Some coils also run strong (normal) until they get hot then loose their fire.
Open for suggestions.
Old Feb 18, 2009 | 11:20 AM
Coils and ICMs generally should be replaced after about 150K miles.
dctaz37
Nov 12, 2008 02:24 AM
bow_hunter
14
Sep 7, 2008 08:30 AM
tha_next_Kobe
Sep 5, 2008 11:55 AM
totenkopf
May 31, 2007 03:36 PM
dgaf3888
Dec 27, 2006 06:43 AM
