AC blows warm air at idle
Old Jul 15, 2009 | 12:11 PM
Perry's Avatar
Default AC blows warm air at idle
My 1996 CIVIC DX has begun blowing warm air at ide. When I turn the AC on at idle, the fan doesn't kick in until I rev the motor above 2000 RPM, then the fan slows down quite a bit when the motor is at idle but remains on. The AC blows very cold air at cruising speed.
The condenser fins seem to be okay, any ideas to what the problem might be?
Old Jul 15, 2009 | 12:26 PM
You may have a bad condenser fan relay in the under-hood fuse box:
Old Jul 15, 2009 | 12:52 PM
Also check the A/C ground wire which should start from the condenser fan and go to the car body.
The condenser fan should run at full speed all the time the compressor is engaged.
Old Jul 15, 2009 | 02:12 PM
Perry's Avatar
Thanks guys, I'll check the condenser relay and ground wire.
Slammed98silvercoupe
Sep 24, 2012 10:30 AM
TexusMain
Jun 14, 2012 04:40 PM
Firecivic
Apr 14, 2010 05:00 PM
staffordgt
May 8, 2009 11:22 AM
pkennedy
Nov 21, 2007 07:14 AM
