AC Trouble
Old Jun 1, 2011 | 02:36 AM
Mnstrkttr's Avatar
Default AC Trouble
Hi All,
I have a 1994 Honda Civic EX with 245,000 miles on it. I have had it for about 1.5 years. I bought it from father in law in the winter. He said the heat didn't work so good. I seen that the engine temerature never got to operating range so I replaced the thermostat. then the heater worked great. Now that it is very hot outside the AC will not blow cold air. I found out that before I replaced the thermostat the AC worked extremely well. I really didn't think that this would affect my AC. I always thought it just didn't blow cold air. Anyone have any suggestions?
Thanks
Old Jun 1, 2011 | 04:36 AM
Make sure that the heater control valve on the firewall (engine side) is closing fully when you move the dash lever to full cold. It is very common for the push-pull cable to get out of adjustment, allowing hot water to continue to flow to the heater and fight the A/C. The heater will win.
Old Jun 1, 2011 | 05:06 AM
Mnstrkttr's Avatar
Thanks so much for the help.
I will check tonight & let you know if this is the problem.
Old Jun 2, 2011 | 02:46 AM
Mnstrkttr's Avatar
I checked it out & it seemed that there was a plastic clip hanging there so I put it back together & is closing the valve better. Refrigerant was low so added some. It was cooler but so was the air temp. It'll be hot today so that will be the true test. Will post back today.
Old Jun 2, 2011 | 01:13 PM
Mnstrkttr's Avatar
It's still blowing cold.
Thanks again for the help.
CatsnotCars
Jan 28, 2015 12:24 PM
niteryder
Jan 23, 2005 06:55 PM
zeppelinfire05
Aug 22, 2004 09:45 AM
derekhell
Aug 3, 2004 05:47 PM
danman114
May 27, 2004 04:13 PM
