audio shuts off when brake pedal is pressed
Hello,
I have a Honda Civic HX 1997
It just started to happen lately that whenever I hit the brake pedal, my audio system shuts off. It was like suddenly the electricity got cut off from the audio system.
I was wondering if anybody could tell me what the problem is ? I believe it's not the battery since it's a pretty new battery.
Thanks
Thanks
ORIGINAL: stlhondas
im having kind of a similar problem but when my brake pedal is pressed my interior lights dim down and head lights flicker weird
First charge your battery (some auto parts stores offer this as a free service) and clean the battery electrodes/connectors to see if the problem goes away.
As mentioned by basbal123, you may have a loose wire/connector. Check for a loose connector at the rear of the audio unit. Also look for a loose wire around the brake pedal (picture). You might be pulling on a wire when you press the pedal.
Alternatively, the audio unit is wired into the brake light system, and the latter circuit is now interfering with the former.
Justin Gomez
Jul 27, 2013 05:04 PM
usmcyoung
38
Oct 1, 2009 04:27 PM
Ed Fisher
Aug 20, 2009 11:47 AM
icecolor
Mar 24, 2009 08:18 PM
syedz7
Feb 4, 2006 06:25 AM
