belt squeak after starting up
Old Mar 25, 2006 | 01:01 AM
seanperia's Avatar
Default belt squeak after starting up
what could be wrong when a belt squeaks (most likely a timing belt) after i start up and when sometimes i downshift?
my car is a 1994 Honda Civic DX it has a 165xxx miles.
Old Mar 25, 2006 | 02:07 AM
99civic_boosted's Avatar
Default RE: belt squeak after starting up
Typically when a belt squeaks it is the belt slipping on the pulley. The most common cause of this is a glaze on the belt. Over time the belt will become glazed or if it is loose it will do so at a much faster rate. Simple replacing the belt should fix this problem. A timing belt has teeth that lock the belt and timing gear which would make it very unlikely to be your culprit. I would look closely at you’re A/C belt then the ALT belt.
Old Mar 25, 2006 | 08:48 AM
06Si's Avatar
It is deffinately not your timming belt. If your timming belt slips you will know it and not by squeks. It will run badly if only maybe one or two teeth. Much more than that your engine will be screwed. You will be replacing much more than a belt.
Old Mar 25, 2006 | 05:11 PM
magneticblue's Avatar
possible water pump wear
Old Mar 25, 2006 | 05:17 PM
joey's Avatar
ahh it's almost certainly your alternator belt....your timing belt can't possibly squeek it has teeth on it and if it slips then yer car don't work.... yer alternator has 2 bolts on it, one to hold it onto the engine and one for adjustment (it is on a long slider...) loosen the bolt on the slider, use a pry bar and put some torque on the alternator... push it away from the motor, so the belt pulls tighter... tighten it and squeak no more.
Old Mar 25, 2006 | 09:59 PM
06Si's Avatar
Your adjustment bolt has a lock screw on it to keep it from moving so make sure you loosen that first.
Old Apr 18, 2006 | 10:34 PM
Fastline42david's Avatar
Timing belts dont squeak...They slip and all goes to hell so its not that...Check your alternator belt...Ill put money on that one...Or if you cant tell put a voltage gauge in your car and if the needle jumps back and forth when it squeaks that is defenitly your problem...good luck
smallsc111
Jul 24, 2011 11:53 AM
Live_4it
Oct 29, 2007 10:14 AM
totenkopf
May 31, 2007 03:36 PM
kjreinha
May 27, 2005 05:24 PM
Frankyoz5711
Sep 3, 2004 07:33 PM
