Big Problem With 91 Civic With Engine Swap
Hey everyone I have a 1991 Honda Civic Std or DX model, I bought it with an engine swap with a SOHC 1.6L ZC engine. I brought it for an e-test and it failed here are the numbers
40KM/H
HC ppm 110 Fail
CO % 0.19
NO ppm 3686 !!!!!! Fail
The idel rpm is 1124
More info to come! Any info can help!
40KM/H
HC ppm 110 Fail
CO % 0.19
Yeah I havent checked the car but I will but, I dont think thats what it is, I should of did more looking into, but it was a perfect condition car mint and I got it for 1400Canadian.
Alright here is the whole E-Test sheet.
40KM/H
Limit Reading Result
HC PPM 75 110 Fail
CO% 0.42 0.19 Pass
NO PPM 0864 3686 Fail
RPM 1991 Valid
Dilution 13.87 Valid
Curb Idle
HC PPM 200 82 Pass
CO% 1 0.16 Pass
NO PPM BLANK BLANK BLANK
RPM 1124 Valid
Dilution 13.34 Valid
I was talking to the mechanic, calls himself the "Honda Expert" and he has a good rep from a lot of people I know. He said that the wireing was sliced and diced for the engine swap, my TPS sensor is tampered with, possibly a new ECU (but I know its the right one and he agreed after I explained). Could it be that the wireing is all messed up? He said its gona be a costly job. I can agree myself on the wireing cause its a 1991 Honda Civic Standard model, and I heard you need a whole new wireing harness to fit a 1.6L ZC engine. I think the guy was just lazy who did the swap, any info would be GREAT!
40KM/H
HC PPM 75 110 Fail
CO% 0.42 0.19 Pass
RPM 1991 Valid
Curb Idle
HC PPM 200 82 Pass
CO% 1 0.16 Pass
RPM 1124 Valid
I'd drop the cat first and see if it at least has some potentially active material inside. If it has an active CEL and runs without the CEL on it may be in pretty good shape as far as the controls go.
p3anutboi
Aug 23, 2010 12:47 PM
fispod
Apr 18, 2006 11:16 AM
