Brake and Gas Pedal Removal
I had to pretty much finish the AT to MT swap on the teg. Clutch pedal is cake compared to the brake pedal. Just a VERY tight area to work in.
If you think of it, can you take a picture of where the return spring from the pedal hooks onto the bracket? I haven't done that yet and it is a PITA to drive with like that. Brake pedal should only be 3 things: the top bolt (which it pivots on), bolt or clip (cant remember) for the pin connecting it to the BB/MC, and the return spring.
Are you swapping to a MT harness for the clutch safety switch etc?
wyclef
Aug 17, 2010 05:45 PM
Ed Fisher
Aug 20, 2009 11:47 AM
blinky120
Aug 26, 2008 07:39 PM
