burning oil bad
Old Aug 23, 2007 | 08:55 AM
kurtina2005's Avatar
Default burning oil bad
HELP!!! i have a 2000 civic ex .i blew out an exhaust valve. got remanufactuered head now im burning 1 quart of oil every 100 miles. any thoughts. compression test good ,leak down test good ,smoke test good , i m at a loss,............head also check out good????????????????
Old Aug 23, 2007 | 09:03 AM
2slo4u's Avatar
Default RE: burning oil bad
You're burning 1 quart of oil every 100 miles and there is no smoke?
Old Aug 23, 2007 | 09:14 AM
yes there is smoke !!!!!!!!! the smoke test showed nothing wrong
Old Aug 23, 2007 | 09:32 AM
2slo4u's Avatar
There is smoke, but the smoke test showed nothing wrong? I'm confused. [&:]
How did you do a smoke test?
Old Aug 23, 2007 | 09:47 AM
mac tools makes a machine that blows smoke at about 100psi . you blow smoke into different ports, valves, or what have you and watch where smoke escapes from....hopefully nothing leaks where it shouldn't
Old Aug 23, 2007 | 11:21 AM
Take the plugs out and inspect them. If one is really oily and the rest clean, that's the problem cylinder. If it's the one that had a bad valve before, the piston/cylinder/rings may have been damaged by pieces of the valve. If they're all oily maybe you got a really bad rebuild job with the wrong valve seals or something.
Does it smoke at idle, or just when you drive it?
Old Aug 23, 2007 | 12:02 PM
all four cylinders are burning oil the same! the guy i got the head from (jnc) said everything check out good on his head????
Old Aug 23, 2007 | 12:07 PM
not sure ifi can trust him?? head is off car right now. waiting for replacement head jnc is sending another but he says there was nothing wrong with the first one?
Old Aug 24, 2007 | 03:12 AM
Did you consider running a compressoin test to see if your rings are at fault?
Old Aug 24, 2007 | 05:43 AM
compression was 185-190, leak down test was @1%of 100psi ? so there shouldn't be a problem there. is there anything else on the intake side of motor that could cause this besides rings and valves?
jaysdogjazz
13
Nov 21, 2015 09:07 PM
oilltd
Jun 10, 2008 04:06 PM
copyguy6188
Feb 3, 2005 07:15 PM
toondebt
Nov 27, 2004 08:24 PM
