oil burning?
Old Feb 3, 2005 | 09:00 AM
copyguy6188's Avatar
Default oil burning?
Hey guys I am a newbie an could use a little help. I have a 96 hatch with a JDM type R motor (b18c5). When i get into vtec at full throttle in 3rd - 5th gear i blow a puff of blue smoke and then to a darkish white smoke.. I pulled my plugs and they are all clean as a whistle. I go through about 1 qt of oil every 2500 miles and only when i get on it. What do you think? Blow-by? Thanks in advance for the help guys.
Old Feb 3, 2005 | 07:06 PM
sacicons's Avatar
Default RE: oil burning?
do a compression test and then do it again after pouring a few drops of oil into the cylinders. if its higher in one (or more) cylinders with the oil, then its rings. if not, it might be valve guides. good luck.
Old Feb 3, 2005 | 07:15 PM
Kappa22's Avatar
Well, if you're getting it through the rings, they're not that bad compared to most cases. A quart every 2,500 isn't that much.
jaysdogjazz
13
Nov 21, 2015 09:07 PM
oilltd
Jun 10, 2008 04:06 PM
97CivicEX
Apr 6, 2005 07:25 PM
toondebt
Nov 27, 2004 08:24 PM
