Buying a transmission what to look for?
Old Apr 27, 2008 | 10:34 PM
poorb0i's Avatar
Default Buying a transmission what to look for?
I'll be buying a 5spd tranny off a 99 civic with 68k miles soon. What should i look for before taking it home?? Shift fork?bearing? idk????
Old Apr 28, 2008 | 05:41 AM
Default RE: Buying a transmission what to look for?
Buying a used part locally, they should have a guarantee on it. If it's noisy or doesn't shift right you can take it back and get another one or your money back.
You should be able to move the shift rod by hand or with a little leverage and select all gears. Also spin the shaft and see if it is smooth. Really it has to be in a car to be sure it is OK.
Old Apr 28, 2008 | 09:37 AM
danomatic93's Avatar
June 2010 ROTM
Do you know what model Civic it's coming out of? Because EX trannys are built for "acceleration" and DX, HX, LX, VX, VX etc are built for economoy. Do you have a preference. If it's the "economoy" kind it'll be stamped with A000. If it's the "acceleration" kind it'll be stamped with B000.
See this link to find where the stamp can be found.
https://www.hondacivicforum.com/m_413787/tm.htm
Old Apr 28, 2008 | 10:22 AM
poorb0i's Avatar
i guess it doesn't matter which one really. but is $300 good buy? most of the used parts place around here sells for $450. They say its for Vtec so i assume its most likely EX cuz they asked ifit was Vtec or Vtec-e.
Old Apr 28, 2008 | 12:07 PM
Put the same one your car came with, or you may get a check engine light as the ECU is comparing road speed to engine speed and the ratios are not as expected.
Old Apr 28, 2008 | 12:23 PM
June 2010 ROTM
ORIGINAL: mk378
What? This is a manual trans right!?!? If this is for a manual transmission you can put ANY 92-00 D-series transmission on the car. I drive a 93 Civic and put on a 96-00 EX manual transmission that I bought for 100.
If this is reguarding an Automatic transmission dissregard anything I've said, as I know zilch about auto trans.
A manual trans should run you 100-200 bucks from a local seller or 200-300 bucks from a dick company.
An auto trans shoud run you 250-350 bucks from a local seller or 350-450 bucks from a dick company.
Old Apr 28, 2008 | 12:33 PM
OK I'm wrong then. It must do something to detect if the VSS signal is as expected, but maybe it's not that critical.
Old Apr 28, 2008 | 12:56 PM
June 2010 ROTM
My VSS reads properly and I didn't have to re-wire anything. My stock plug for the speedo sensor pluged right in. ne CELs, no problems.
Old Apr 28, 2008 | 06:04 PM
poorb0i's Avatar
I cant find the 5spd anywhere for that cheap cheapest is $300. Im doing a atx to mtx swap taking out the CVT cuz its jacked and putting this in. I know there will be a CEL but ill live with it.
addiction2bass
Jul 5, 2007 12:13 PM
iceland_potter
Jun 21, 2007 07:19 AM
brokenarmboy19
May 11, 2007 09:01 AM
xposigroovex
May 26, 2006 10:53 PM
Dumont
Feb 27, 2006 09:49 PM
