A/C belt replacement
Old Dec 16, 2007 | 08:41 AM
PREKGSR's Avatar
Default A/C belt replacement
I just bought the a/c belt and i need to know how to replace it , is it hard to do? i also bought the alt belt too just to be safe.
Old Dec 16, 2007 | 11:38 AM
Default RE: A/C belt replacement
What year and model Civic? Why not replace the Power Steering belt as well while you are at it?
Old Dec 16, 2007 | 12:35 PM
PREKGSR's Avatar
its a 00 . well i was going to to that as well but the place i bought the belts from didnt have the p/s one
Old Dec 16, 2007 | 12:51 PM
1) Remove PS pump belt (picture 1).
2) Remove A/C compressor belt (picture 2).
3) Remove alternator belt by loosening the adjusting bolt and if necessary the lower mount bolt (picture 3).
Install new belts in reverse order. Tighten PS and alternator belts using a pry bar.
Old Dec 16, 2007 | 12:55 PM
You have to remove the belts in order, so it would be best to have all 3 new ones before you start. I think on that model you will have to undo the lower left engine mount from the frame to get the A/C belt on. Otherwise it is not complcated. It is best done from underneath after you jack up the car and support it securely, take the left front wheel off and take the plastic splash guards inside the fender off.
Old Jun 24, 2013 | 12:53 PM
eliasletona2000's Avatar
I can't see any of the pictures ?
Old Jun 24, 2013 | 01:03 PM
Thread is from 2007. Best to do some searching around the forum first to see if anyone else is having the same problems. All sorts of A/C related threads are popping up now that it is summer time.
sasquatch
May 25, 2007 04:02 PM
joshr799
Mar 22, 2006 08:53 PM
hoppyumr
Nov 23, 2005 02:28 PM
jennifert9
15
Mar 7, 2005 10:17 PM
NCH
Dec 29, 2004 06:38 PM
