A/C Hissing and not cold
Old Sep 27, 2013 | 01:31 PM
Slammed98silvercoupe's Avatar
Default A/C Hissing and not cold
Hello, yesterday I noticed that the ac started to hiss kinda randomly but still cold. Today the ac was blowing warm and still hissing. I noticed that the compressor still cycles on and off, and the condensor fan is spinning.
I took the cover off evaporator where the filter goes and it was dripping a bit of water and the bottom of the expansion valve was cold. Why was this cold and not the hoses coming off the ac compressor. I did notice that the High side hose has green "algae" which I am assuming is leaked freon since I added Dye when I replaced the compressor, condensor, and dryer 5 months ago. So what could it be?
A leak in the High side hose, which leaked the freon? But if the freon levels are low why is the compressor still cycling? Dont have gauges to hook up... any feedback would be appreciated.
Old Sep 28, 2013 | 04:54 AM
Clean off the green stuff and see if more comes out. If it does, there's a leak. Loss of performance over a few days also strongly suggests a leak. With a low charge, the expansion valve and part of the evaporator may get cold but not the whole thing. So really everything is pointing to a leak in that high side hose.
Old Sep 28, 2013 | 08:39 AM
Thanks, the high pressure hose was leaking at the bottom metal crimp and the system was almost empty. Replaced, vacuum, recharged and blowing around 40 degrees. Thanks again...
Old Sep 30, 2013 | 12:03 PM
CivicDuty01's Avatar
Glad to hear you got it fixed!
DocThaStar
Mar 29, 2007 08:37 AM
Faithbleed
Feb 5, 2007 04:57 AM
windcalmer
Jul 9, 2006 11:29 AM
willay
May 20, 2006 01:42 PM
02CivicEX
Mar 8, 2005 12:31 PM
