A/C Problems
Old Aug 4, 2009 | 03:42 PM
Rbarrera08's Avatar
Exclamation A/C Problems
Hey,
So i have a 1998 Honda Civic. I just replaced the A/C compressor and dryer. However the air isnt exactly cold. The compressor was charged, it cools a bit, but not like it used to. What could the problem be? I was thinking the expansion valve but is there anyway to tell if its bad?
Thanks,
Rey
Old Aug 4, 2009 | 04:06 PM
Did you have it evacuated before it was charged? Did you have it charged at a shop? If you charged it yourself, did you use a gauge manifold that reads both the high and low pressure sides of the system? And, if you did it yourself, are you sure you did it properly? (the kits at the store are junk)
Old Aug 4, 2009 | 04:12 PM
Rbarrera08's Avatar
I took it to a shop. they did evacuate it. they had called me and told me that my car was ready, i went to pick it up and on the way home it never got cold. So i took it back and they notice that there wasnt any freeon so they figured it was a leak, they supposedly fixed it but it still isnt cold.
Old Aug 4, 2009 | 04:15 PM
Need more details... is the temperature of the A/C after it was supposedly fixed any different from how it was directly after the evacuation/recharge?
Old Aug 4, 2009 | 04:17 PM
Rbarrera08's Avatar
there was a slight difference. not alot though.
Old Aug 4, 2009 | 04:19 PM
well if the lines are opened you should replace the Orings! if you or the shop just tightened up the lines and kept the stock O rings they can easily leak from being old and dry... if it looses pressure again then i say you need to replace EVERY O ring even ones that where not opened up. thats where the system typically leaks from!
Old Aug 4, 2009 | 04:23 PM
Yea, the first thing I would do is take it back and have them check it again to see if it leaked again.
jrobles26
Jan 1, 2006 11:05 PM
green98lxsedan
Aug 9, 2004 02:30 AM
lil frog
Jul 8, 2004 08:07 PM
Tenchi_Wannabe
Jul 6, 2004 02:15 AM
tgamer
Jun 27, 2004 06:29 AM
