A/C UNIT
Old May 25, 2007 | 01:16 PM
silverbullet01's Avatar
Default A/C UNIT
I have a 98 civic EX and when i turn my ac on, its shakes my car a little, like my steering wheel and its really annoying how it shakes, is there something i can do or change or something so that it wont do that when i turn it on? thanks
Old May 25, 2007 | 01:38 PM
Masonn's Avatar
Default RE: A/C UNIT
well, the same thing happens to my car. i drive a 95 cx... i thought it was normal because i never owned a honda before haha. or could it be a fault in the car?
Old May 25, 2007 | 02:49 PM
Tim706's Avatar
I'm assuming you only notice the rumble at idle, if at other speeds then there is likely a fault in the compressor.
At idle there is really no bypassing it, save for turning the a/c off when sitting at a stop light or the like. The cause is the increased load placed on the engine at such a low rpm, usually around 750 rpm(idle). The rumble is you feeling the individual pulses as each cylinder fires. You only notice it with the a/c on because of a) the increased load, therefore each cylinder has to fire 'stronger' to keep it at idle, also with the increased load the engine idle can actually drop down a little (more common on older vehicles, as compressors were not as efficient) which only further enhances the vibration felt.
aprice
Sep 9, 2005 07:31 PM
superflycivic
Oct 12, 2004 10:18 PM
00civiclx
Sep 30, 2004 04:48 PM
00civiclx
Sep 29, 2004 11:35 PM
ohbiskits
Jun 22, 2004 02:13 PM
