Car Bucks Forward
Old Oct 2, 2008 | 10:44 AM
Originally Posted by mk378
There are no spark plug wires. The coils fit directly on top of the plugs.
I was referring to the ignition wires running between the ECU and coil. As you mention, these wires are not called spark plug wires, but if they or the connector at the coil are faulty, misfiring can result.
The OP should get the crank sensor working solid before even thinking about whether the timing is going to be right.
I agree. Fixing the CKP sensor is the number one priority. Then go from there.
Old Oct 2, 2008 | 11:09 AM
Originally Posted by bobbob2x
Also am I going to need any other parts if so which ones.
You probably need to remove the valve cover. If so, I'd recommend that you replace the valve cover gasket.
Old Nov 1, 2008 | 06:24 PM
bobbob2x's Avatar
I've been stalling my butt off doing this, I really don't want to mess any more things up. Although in the mean time I did replace my mounts and the front one was busted but i still think my car is still doing this crazy mysterious problems.
Hackuuna Matata
Apr 3, 2009 07:25 AM
susan
May 4, 2006 01:20 PM
gili_91hatch
Oct 7, 2005 03:45 PM
Street Sniper
Jul 14, 2005 10:16 PM
