car won't start
Old Aug 13, 2005 | 07:14 PM
rzimmer11's Avatar
Default car won't start
GSR engine cranks but won't fire.....pulled off the fuel line to the fuel rail and turn on the ignition and no fuel. So besides a probable faulty fuel pump....can anyone think of anything else that could effect the flow of fuel???
Old Aug 13, 2005 | 07:45 PM
maachan513's Avatar
Default RE: car won't start
Empty tank????? Clogged fuel filter???? Faulty pump??? Faulty pump relay????? Kinked / pinched fuel line?????
Old Aug 13, 2005 | 09:00 PM
shoobie's Avatar
I just had an intermittent starting problem in the heat on my 94 Civic and it turned out to be a bad main relay...
Old Aug 29, 2005 | 08:39 AM
SkItZiAnIsT's Avatar
possibly battery connection cables? jiggle them around and have a friend hold the key in ignition
Old Aug 29, 2005 | 11:29 AM
Super Mario's Avatar
ORIGINAL: rzimmer11
He's got no fuel!! He says he's not getting spark, but he's pulling off the fuel rail and now he's not getting fuel. So it could be anything alon the way from your fuel tank up to your fuel rail. fuel filter, FPR(fuel pressure regulator), fuel pump, fuel pump relay(like he said), pinched fuel line. your first bet would be to go from easies to hardest so start with checking your fuel pump and fuel pump relay. then go from there.
Old Aug 29, 2005 | 08:52 PM
sacicons's Avatar
its probably the relay. i havent heard of a huge problem with honda pumps dieing.
Old Aug 29, 2005 | 10:00 PM
redcivic99's Avatar
check the fuses to the pump and to the ignition system, mine belw one time whenit wouldnt start
Old Aug 30, 2005 | 02:57 PM
Kappa22's Avatar
ORIGINAL: sacicons
Ditto
dkd
Nov 30, 2020 07:38 PM
David_S
Oct 24, 2013 10:06 AM
forrealb50
15
Nov 12, 2006 01:52 PM
Smeghead009
Jun 1, 2005 07:46 PM
bek3k1
Mar 18, 2005 08:36 PM
