Cel #9 help needed
Old Apr 26, 2013 | 12:32 PM
civik1's Avatar
Default Cel #9 help needed
Hi,
Ok, heres my situation. I was pulling a code 41(O2) went through and re-soldered all the wires and thats resolved. But im still pulling a code 9 (Cyl Sensor). I checked the resistance at the 8 pin connector and its well within range(bout 415). The dizzy and ecu(p28) are new. What is my next step in resolving this Cyl sensor code? Thank you
Old Apr 26, 2013 | 02:50 PM
Unplug the ECU, leaving distributor plugged in, and measure sensor resistance at the ECU plugs. This tests the wiring all the way back through the harnesses and distributor. Also check for faults to ground. With ECU unplugged, the sensor circuits should be open circuit to ground.
Old May 1, 2013 | 03:24 AM
civik1's Avatar
Thx. What should the sensor resistance be at the ECU plugs?
Old May 1, 2013 | 05:13 AM
The same as at the distributor, since the wiring has essentially zero resistance.
mikeyb16a2
Nov 21, 2006 08:59 PM
THOR50
May 25, 2006 05:53 AM
njdan
Dec 5, 2005 07:08 PM
Auto98EX
Nov 19, 2005 11:01 AM
b16Ek4
May 25, 2005 08:48 AM
