check engine light after trans swap.
Old Sep 21, 2008 | 02:32 PM
99civicExCoupe's Avatar
Default check engine light after trans swap.
hey guys i just did an auto to manual trans swap and the second day after i got it done it threw a check engine light. it drives fine and there is no knocking or anything of that nature. i was wondering if anyone had any suggestions on what might have caused that. thanks alot.
Old Sep 21, 2008 | 02:55 PM
You need a different ECU for manual transmission. If you still have the stock one that came with the automatic, it is expecting certain readings from the VSS that correspond to the gearing of the automatic.
Old Sep 21, 2008 | 02:57 PM
I put a new 5speed ecu in from a 99ex that is why i dont understand whats wrong it drives perfect and the check engine like came 2 days later. should i take it to autozone and see if a code pops up? would that help the problem?
Old Sep 21, 2008 | 03:43 PM
Yes. Use the usual procedure to diagnose. It may not be related to the transmission swap.
Old Sep 21, 2008 | 03:44 PM
i'd clear it first to see if it wasn't just some random CEL
clear the code by resetting the ECU (remove backup fuse from under hood fuse box for like 5 minutes. plug it back in, start the car, don't touch the gas pedal at all, and let it idle for 5 minutes. after that, you're good to go)
see if the code comes back
if it doesn't come back... problem solved
it it comes back, get it scanned and go from there
Old Sep 21, 2008 | 03:51 PM
OK great ill try that. thanks alot for all the help.
Old Sep 21, 2008 | 04:49 PM
Pull the code at home using the jumper wire method (see link in my signature). Note the code and then clear it from the ECU.
Old Sep 23, 2008 | 06:24 AM
ok so i just disconnected the ground cable from the battery and it cleared. thank you guys for the help.
Old Sep 23, 2008 | 06:44 AM
good, hopefully the code stays away and doesn't throw again.
fclaridge
Jan 27, 2015 03:07 PM
bojadada
Mar 25, 2014 03:50 AM
98 EJ8
Mar 28, 2011 02:40 PM
jared0183
Jul 12, 2010 05:37 PM
MasterJT
May 15, 2010 05:45 PM
