chk engine light on & rpm's rev...
Old Mar 25, 2011 | 11:42 AM
MikeDun's Avatar
Default chk engine light on & rpm's rev...
Have a 98 Honda Civic LX 5 speed.. Check engine light is on and rpm's rev up w/loss of power? Did replace the plugs & wires a month ago. The check engine light on was catalytic converter misfire & O2 sensor. Whats the problem?
Old Mar 28, 2011 | 07:10 PM
xbezubzx's Avatar
from the way that sounds you i bet that the 02 sensor said bank 1 sensor 2 right? your cat is probably bad and giving your post cat 02 a funny reading causing it to send weird fuel trims to your ECU.. did the cat code say catalyst deficiency? if so i would start with a cat they are pretty cheap.. hard to say without actually seeing it.. don't waste too much money on guessing have it looked at..
acf7efi
Oct 10, 2021 03:34 PM
vr4
17
Aug 12, 2008 07:05 PM
saninca
Aug 4, 2008 08:24 PM
Boods
Sep 28, 2006 10:43 PM
xllybx
Jul 8, 2004 09:20 PM
