Civic DX for the 16 year old
Old Nov 17, 2008 | 05:18 PM
  #21
Originally Posted by NEW2MALIBU
I was thinking of the sea foam thing also. It is strange tho, if I use the prybar to pry it up it takes a bit of force. But when it sits for a few minutes it comes up on its own.
Mitch
bad valve spring maybe? and the heat causes it to stick. idk
Old Nov 17, 2008 | 05:23 PM
  #22
NEW2MALIBU's Avatar
If I screw around with it and get it running it seems fine. Turn it off and it fires right back up, but let it sit for a while and it won't start. I haven't started it since yesterday so it is cold now and that valve is sticking sure as ####.
Old Nov 17, 2008 | 05:28 PM
  #23
well then i would definitely use some Seafoam since you can get it running. Pour 1/3 bottle in gas tank, 1/3 in crankcase, and then while the engine is running suck up 1/3 with your brake booster line (slowly... the engine will bog down while doing this and that is fine, just don't let it die from sucking in too much at a time). You never know, it could help. After all, Seafoam is magic.
Old Nov 17, 2008 | 05:29 PM
  #24
Did you check whether the cam and crank are out of synch by a tooth on the timing belt?
Old Nov 17, 2008 | 05:36 PM
  #25
NEW2MALIBU's Avatar
That was my next step, but I stopped when I saw the valve hanging up.
Old Nov 17, 2008 | 05:40 PM
  #26
If the timing belt has slipped, then the valve is likely damaged.
Old Nov 17, 2008 | 05:44 PM
  #27
NEW2MALIBU's Avatar
Right,that makes sense I will rip the top cover off and take a look.
Old Nov 17, 2008 | 06:22 PM
  #28
NEW2MALIBU's Avatar
It was only off by like 5 teeth, Do you think that could be the problem, Duh. Thank you guys for all your help, I really do appreciate it you guys have a good site here. Thanks again. Guess I will look for another car for the kid.
Mitch
Old Nov 17, 2008 | 06:27 PM
  #29
Did you set the engine to TDC before you determined if it was off? If the timing is proper, the crank and cam will be able to be at TDC at the same time.
Old Nov 17, 2008 | 06:33 PM
  #30
Ouch!
I'd still play with it now that you know the problem. Maybe fix the timing and rebuild the head yourself. I'm sure we can find all the specs you need, and you can probably do the labor yourself. You seem handy with engines.
