Civic jerk between 1st and 2nd
Old Aug 14, 2006 | 12:56 PM
bonez's Avatar
Default Civic jerk between 1st and 2nd
My 99 Civic auto trans. jerks between 1st and 2nd. It seems it jerks harder if you accelerate harder. You can back off the throttle and stop the jerk but this is getting annoying. Took it to a trans. shop and he said alot of Hondas shift hard between 1st and 2nd. Ususally because of bad motor mounts (stiff). Suggested just keep backing off gas. I havent replaced spark plugs on this 4 cyl. and I have 65k miles, and am now throwing a P0165 code. Could this all be related? Too much fuel in exhaust because of a bad plug and causing a jerk when it does fire? Or is it totally separate?
Old Aug 14, 2006 | 01:11 PM
fglaustin's Avatar
Default RE: Civic jerk between 1st and 2nd
dont think i would believe in the 100,000 mile spark plugs.
I would do a tune-up and then see if you have the CEL on.
If so, then go-about fixing that, next.
Old Aug 15, 2006 | 06:53 AM
bonez's Avatar
I replaced the plugs last night with Honda plugs and replace the air filter too. Before I replaced them, I did notice every once in a while a little stutter (from lack of detonation I guess). That hasn't reoccured yet....but the jerk between 1st and 2nd on hard acceleration is still there. Still have a check engine light from p0135 o2 sensor as well....Will be troubleshooting that today. Mine is a 4 wire blk,blk, white, green. I know white is signal, green is ground, and two blacks are heater power. Does the heater circuit read low ohms when cold and then rise as its heated. And if I dont see a low reading while disconnected from the car its bad? or do you have to have power from car before it will read anything?
Old Aug 15, 2006 | 11:01 AM
fglaustin's Avatar
are you talking about the front O2 sensor, or the one in the back ?
Old Aug 15, 2006 | 01:56 PM
Remmy's Avatar
Its your tranny. Check with your dealership to see if its being recalled. Check the forum TSB's to see if your tranny is on the list. This is a common thing. 99% of the time its harmless.
Old Aug 15, 2006 | 09:15 PM
bonez's Avatar
Front o2 sensor....primary 02 heater circuit....autozone has bosch for 82.00 and includes plug so no splicing. I sure hope youre wrong Remmy, but I have suspected all along I guess. I see a bunch of TSB's for 1999 Civic tranny but it just gives a summary and not alot of detail. Any suggestions?
NellyBly15
May 27, 2009 07:02 AM
fdiddy
Feb 21, 2009 07:40 AM
honda_civic84
Jul 6, 2008 05:36 AM
Tomo!
Apr 28, 2006 02:02 PM
mill$civic
Jan 19, 2006 01:08 PM
