Clutch pedal wont come back up!! Help needed
Old Dec 19, 2009 | 02:06 PM
ekblackmagic's Avatar
Default Clutch pedal wont come back up!! Help needed
Hello everyone im new to this forum. I got a 1997 EK civic coupe 5 speed. its got 228,000 miles and still goin but today I put my foot on the clutch and went to put the car in first and it wouldnt go into gear. I turned the car off and pressed the clutch and the pedal went down but wouldnt come back upp. Im thinking my master cylinder is done but im not sure. Has anybody heard of this before or can point me in the right direction?
Thank
Old Dec 19, 2009 | 02:13 PM
Could just be out of fluid. Check the fluid reservoir on the firewall under the hood and add brake fluid if necessary. Then it may start working again or you may need to bleed it. Check for leaks if the fluid was gone. It'll generally leak from the slave cylinder under the rubber boot, or from the master cylinder and run down the firewall inside the car.
Also something catastrophic could have happened, such as blowing the hose from the car to the slave cylinder, or the seals in the master cylinder.
Old Dec 19, 2009 | 02:24 PM
Will do. Any other suggestions???
Old Dec 21, 2009 | 07:32 AM
Checked my fluids and they are both up. Im thinking its that slave cylinder as well.
Old Dec 21, 2009 | 07:49 AM
aaricwon's Avatar
I had this happen in my Jetta and it turned out it was just some cable.
Old Dec 21, 2009 | 08:07 AM
There's not much to go wrong with the slave cylinder other than leaking, and then the fluid would be gone. Many people though do replace both cylinders at once to avoid trouble with the other one in the future.
One guy here did have the lever on the transmission crack and bend, that is unusual but it would cause the symptoms you have.
Old Dec 21, 2009 | 08:09 AM
pump the pedal with your hand and have somebody watch the slave cyl, on the trans
does it move??? have you tried to bleed it?
Old Jan 1, 2010 | 06:38 PM
yup. it was def the slave master cyl. blead it, changed it, put fluid in, car runs great.
KAH1980
Sep 15, 2014 07:12 PM
jyn
Mar 25, 2009 04:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
93SiHb
Oct 2, 2005 01:02 PM
02CivicEX
Feb 28, 2005 03:27 PM
