could be the distributor?
Old Jun 4, 2006 | 03:35 PM
Ramon 91si's Avatar
Default could be the distributor?
I got some problems with my 91' civic SI. Everithing start with the car turnig off by himself with no spark at all, then in less than a minute stars working just fine. One day i change my ecu for a pr3 ecu from a jdm b16, then the car start with the same thing more ofthen, but i knew that the pr3 ecu was looking for the knock sensor wish my car doesnt have, so i change my ecu again for the factory pm6 with a spoon sports chip in it, and the car start to work again and some times doing the main problems. couple of days ago my car just die no spark at all, and now its not working anymore. One time i saw a little of oil inside the distributor. Could be the ditributor my problem? IF SOMEBODY COUL HELP PLEASE
[&o]
Old Jun 4, 2006 | 11:04 PM
AgentofDarkness's Avatar
Default RE: could be the distributor?
Could it be the distributor? Yea. Is it the distributor? I don't know. A number of things can cause a no spark condition. If the ignition coil is fried then you won't get any spark. If your ICM isn't working then you won't have any spark. I would check the resistance of the ignition coil, but i don't think that is your problem since it works sometimes. Since it works sometimes, it might be a sensor that is giving you the problem. The TDC, throttle, coolant, and MAP sensors are all used by the PCM to determine when the spark should be created. One of these sensors could be giving the PCM false readings and causing it to make the spark at an incorrect time.
Old Jun 4, 2006 | 11:08 PM
Pete's Avatar
Agent of Darkness is a bad dude
Old Jun 4, 2006 | 11:44 PM
ORIGINAL: Pete
I swear i didn't do it! (does bad mean bad or does bad mean good?)
Old Jun 5, 2006 | 07:51 PM
Ramon 91si's Avatar
thanks i will check on that
Old Jun 6, 2006 | 12:32 AM
fglaustin's Avatar
i had oil in mine also. just died - but it was missing.
towed home - could never figure it out.
replaced the entire distributor.
Forty04
May 5, 2005 08:05 PM
pedram58
Mar 8, 2005 05:06 AM
blackeyes
Mar 6, 2005 07:26 PM
kpoon
Oct 4, 2004 10:59 PM
forcefedcivic27
Sep 12, 2004 08:06 PM
