crank, no start
Old Mar 9, 2006 | 02:59 PM
tf_94_civic_ex's Avatar
Default crank, no start
I'm new to civics, I have a 94 civic ex coupe, it has a d16z6, 5spd man. I ran into a problem with the car, I have a crank, no start on the car now, me and a friend of mine narowed down the problem to the distributor and not a timing belt issue, I checked for power at the ign. coil with a volt meter and it got power, now comes my question, since the cap and rotor looked ok, is there anything else like a cam or crank sensor that I should know about or look for that may be causing this problem as opposed to anything located in the distributor? Any possitive feedback would be appreciated.
Old Mar 9, 2006 | 03:21 PM
Default RE: crank, no start
nm, I noticed a FAQ thread in an above post, I checked out that link and I forgot about checking the ignitor, I'm gonna check that too and see what happens, if thats not it I'll add to this post.
Old Mar 9, 2006 | 05:25 PM
natecivic92's Avatar
So it has no spark.
Old Mar 9, 2006 | 06:27 PM
right, it has no spark, and it started raining really bad here, so couldn't check it some more.
Old Mar 9, 2006 | 08:17 PM
sacicons's Avatar
its the ignitor or the coil, but more likely the ignitor.
Old Mar 11, 2006 | 02:22 PM
It isn't the ignitor, rotor or distributor, and I was getting power to the coil, both ends, could the coil still be bad, or is there something else I should check. I'm at my last string of patience here guys, could definately use any help possible.
Old Mar 23, 2006 | 05:34 PM
ok, gonna try the coil one more time, gonna get a replacement coil, if this dont work, I'm officially lost
Old Apr 8, 2006 | 02:14 PM
Brian's Avatar
I had the same problem with my Accord last week, spent a couple of days trying to figure it out. I had power at the coil and checked it with an ohmmeter. The readings I got with the ohmmeter were close to spec in the Hanes manual but after talking to a mechanic he told me they didn't mean squat. He was right, after loaning me a coil the car started. Been working great since.
Brian
David_S
Oct 24, 2013 10:06 AM
zerojett
Oct 18, 2011 03:01 PM
greasemitts
Jan 10, 2008 06:38 PM
mike95691
Nov 24, 2007 05:29 AM
crx1984
Apr 16, 2007 07:46 AM
