'D' indicator flashing
Old Mar 10, 2007 | 11:24 PM
farazkhan's Avatar
Default 'D' indicator flashing
I purchased a 2003 Honda Civic. Nearly 80,000 KM.
I notice that the 'D' indicator keeps on flashing during driving and even when the lever is shifted to 'P'.
I did not notice any other problem. Please advice.
Thanks.
Old Mar 11, 2007 | 04:35 AM
windcalmer's Avatar
Default RE: 'D' indicator flashing
Sounds like a bad shifter postition switch. Could be wrong though.
Old Mar 11, 2007 | 05:56 AM
farazkhan's Avatar
When the car is moved the 'D' indicator is lighted as it should happen.
But, after a few minutes , instead of going OFF, it starts blinking. The blinking continues even when the lever is changed to 'R' or 'P'. !!
Old Mar 11, 2007 | 01:44 PM
loFreqncy's Avatar
This is how civics display transmission error codes. The "D" Indicator blinks a certain number of times to indicate which code it is. You'll have to refer to the Honda shop manual, or maybe, a haynes or chilton manual. I am sure this is what is happening.
Old Mar 11, 2007 | 03:21 PM
windcalmer's Avatar
Nice call loFreq. I forgot about that. I know my old accord did that for awhile. I pulled apart the switch and cleaned the contacts and it stopped. But I think you might be right.
Old Mar 12, 2007 | 12:57 AM
Stumasters's Avatar
How about me. My D4 light went out for a while, never came on at all, and D3 D2 and all the others highlighted normaly, but just the other day i hopped in the car, and it was on again. It hasn't gone off again lately, wonder if its a short?
Old Mar 12, 2007 | 02:14 AM
windcalmer's Avatar
^ It might not be a short, how they connect is by a slider type switch. It can get gunked up and not work right. The car is still in the right gear and all because the linkage is seperate from the switch, but the lights get all wonky.
At least they did on my Accord.
Old Sep 4, 2007 | 05:57 AM
rayh059's Avatar
I have the "D" blinking while in gear only along with the check engine light. This idicates a problem in the transmission control which is why it only shifts from 1st - 3rd gear. The error code was for the speed sensor but its an intermittent problem. My guess is that I ran over a stick that wacked a wire, not sure where the sensor or wires are. Its in the shop now, I'm guessing they'll replace the sensor...$$$ great.
fongcom
Feb 9, 2011 03:02 AM
thasizzle02
May 9, 2006 01:45 PM
05reverb
Feb 4, 2006 05:31 PM
kel312
Jul 28, 2005 02:05 AM
