d16a6 head on a d15b7
Old Aug 3, 2010 | 09:32 PM
Black94's Avatar
and also the a6 timing belt has 1 more tooth than the b7 so that'd just make more slack, so thats out of the question
A6 belt has 107 teeth
B7 belt has 106 teeth
Old Aug 3, 2010 | 10:20 PM
The gear won't pick up any slack, it has the same number of teeth and is the same size. The only difference between the Y8 cam gear and the one you already have is that the woodruff key slot is 1/2 a tooth off. The only thing this changes is the synchronicity between the cam and crank, not the amount of slack the belt has.
I think you need a VX timing belt.
Old Aug 4, 2010 | 08:48 AM
Black94's Avatar
what year/model/motor does that come off?
Old Aug 4, 2010 | 09:53 AM
92-95 VX, D15Z1 engine
Old Aug 4, 2010 | 08:02 PM
Black94's Avatar
thanks man i'll give it a try
Old Aug 5, 2010 | 11:06 AM
egstylin21's Avatar
is cylinder 1 and 4 both supposed to be at the top of the block or just cylinder 1
Old Aug 5, 2010 | 11:08 AM
Cylinders 1 and 4 are always in the same position as one another.
Don't thread jack.
Old Aug 5, 2010 | 08:25 PM
egstylin21's Avatar
OK really appreciate it for the info
Mr.Whiteside
Aug 2, 2008 01:36 PM
scottdh20
Apr 30, 2008 12:29 PM
scottdh20
Apr 16, 2008 10:45 AM
BoomBox
ED-EF Swaps
Jun 23, 2005 08:48 AM
BoomBox
Jun 6, 2005 03:45 PM
