Del Sol runs fine, why CEL?
Old Oct 6, 2008 | 06:01 AM
Flippinjig's Avatar
Default Del Sol runs fine, why CEL?
My D16Z6 was blown and I found a D15Z1 so I put it in with the original Z6 head, manifolds and ECU. It runs fine but the CEL came on right away. I flashed the code but can't find what it means. One long flash and eight short flashes. I need help, any thoughts????
95 Del Sol SI
Old Oct 6, 2008 | 07:34 AM
I'm not 100% sure that a Z6 head will work on a D15 block... Did you swap computers or anything as well?
Old Oct 6, 2008 | 08:07 AM
Flippinjig's Avatar
No, I used the Z6 head, manifolds and ECU that came with the car. I swapped to the Z1 motor because the Z6 thru a rod and Z1 was right price.
Old Oct 6, 2008 | 04:41 PM
it should work. that's a common swap, although it's normally done with a d15b7 block, but it shouldn't matter. it should still work.
you're throwing a code 18, which according to my haynes manual or any other source, doesn't exist...
are you sure it's 8 short flashes, and not 7 or 9?
Old Oct 6, 2008 | 05:38 PM
Flippinjig's Avatar
Weird but yes it was one long followed by eight short flashes. I reseated the plugs and pulled the back up fuse to reset the ECU and then it flashed one. ????? I reseated the plug for the o2 and reset the ECU again. No CEL!!!! It just goes to show that you have to get it plugged in really good to keep her satisfied.
Old Oct 6, 2008 | 05:40 PM
odd
don't party too soon, the CEL might come back in a day or so
but i'm pessimistic so don't listen to me
yea, since the code doesn't exist, it was probably a freak CEL like what you described.
Old Oct 6, 2008 | 06:12 PM
Flippinjig's Avatar
Well I'm one step closer to having a nice car like yours. I'd say that is reason enough. An InBev product sounds pretty good right now.
Old Oct 6, 2008 | 06:18 PM
Flippinjig's Avatar
The Z1 wasn't an exact fit but pretty close. I had to slot holes on the power steering bracket and the intake support brace to get them to fit. The Z6 had two brackets that go from the transmission to the block but the Z1 only had holes for the front bracket. I guess it should be fine since I'm not racing it.
livejamie
Aug 12, 2011 06:53 AM
Faramire
Aug 1, 2010 11:42 AM
84runner
Apr 25, 2010 10:03 AM
rcherr642z
Aug 21, 2008 01:20 PM
Mark C
Apr 4, 2008 07:18 PM
