Died out on a hill. Now it wont start
Old May 11, 2011 | 07:26 PM
RolanHI's Avatar
Default Died out on a hill. Now it wont start
Well yeah. Driving up a hill one day, made a turn in 2nd gear and my 93 civic started to bog out. Even after i pressed in the clutch, my rpms didnt raise up and my car died out. I tried starting it up again but it only cranks. I don't know what the problem is Fuel pump? Main/Fuel Relay? Fuses?
Old May 12, 2011 | 10:07 AM
First check for basic power functions. Turn the key on but don't try to start. The CEL should come on then go out, and the fuel pump should run and then stop. Next pull the brake handle up and watch that the BRAKE light on the dash stays on all the time while you try to start. It's powered from the same circuit that runs the ignition system.
Three big reasons for sudden death on the road are a stripped/skipped timing belt, blown ignition coil, or distributor rotor coming loose (screw fell out). So check the cam timing and confirm that the spark plugs fire.
rekomstop209
22
Oct 19, 2012 10:18 AM
tmds3
Feb 23, 2011 10:23 AM
Faithbleed
Jul 26, 2010 01:45 PM
Blue92Civic
Aug 10, 2009 06:08 AM
amgovela
Jun 3, 2009 05:09 PM
