Do i have A/C?
Old Aug 9, 2006 | 04:42 PM
  #21
civicex96's Avatar
Default RE: Do i have A/C?
I have a 1996 Civic EX Coupe and it has 3 belts. 1 for the AC compressor, 1 for the power steering and the other for crankshaft pulley. Maybe the last owner just took off the belt to get better mpg. If you are looking down at your engine, see if you can see a pulley with no belt on it. It should be just under the first belt if I remember correctly.
Good luck! Maybe all you have to do is just install a new belt and voila, you will have COLD AC.
Old Aug 9, 2006 | 07:39 PM
  #22
fglaustin's Avatar
yes; but to rephase, the ac compressor runs off the revolving belt
Old Aug 9, 2006 | 07:46 PM
  #23
seriously_furious's Avatar
alright well i do have three belts... one off the crankshaft pulley... one off the alternator... and im assuming the third belt i see is running off of the a/c compressor.
Old Aug 12, 2006 | 12:53 PM
  #24
deserthonda's Avatar
you cannot see a freon leak,,,,,,,,,,
take car to a shop, have them chk the a/c system,, ,, if system is empty, they need to add some freon and some dye.. if there is a leak they will be able to see the dye ooze out by using some ultra-violet goggles ,,if there is a leak fix the leak .. well depending on where the leak is at it could be expansive ( compressor ) ..
I have seen a lot of pressure hoses leak
dcashley84
Jun 26, 2007 07:44 PM
Pocket[H22]Rocket
Jul 24, 2005 08:29 PM
ohbiskits
Jun 21, 2004 04:24 PM
Wheelbroker
May 23, 2004 12:25 AM
